Blazer stalls then won't start. Fuel Pressure Related i think
Hi everybody i'm new here, Just trying to find out whats wrong with my Grandpa's 1996 Blazer.
It will run fine when it's first started up and run on a short trip, but if it gets run for about 10 miles continously it will stall out. Then if it sits for a little while it will start back up. I checked the computer codes and none were displayed. I also hooked up a fuel pressure gauge and drove it around until it stalled. When running normally it read at about 55 psi. When it was being drivin it would read about 50-60psi. When it was about to stall the motor would hesitate and the fuel pressure gage would jump around. When it stalled the pressure would drop to 40psi. No matter how much i cycled the key on and off the pressure would not go above 45 psi. After I let is set a while I would turn the key on and the pressure would shoot right up to 60 psi and fire right up.
I was thinking it would be the fuel pump but that was replaced about 2 yrs ago. I also heard some stuff about the fuel pressure regulator but i'm not sure if that's it.
Has anyone else had this problem?
I just had this issue on a Saturn last week. Dont ignore the fuel system, but a lot of people are getting results from changing the crank position sensor. You wouldnt think about it because its not throwing a code, but apparently these things are failing like crazy and not being picked up by the PCM. It was the same exact symptoms too. Would start initially, then die shortly after and not restart until about at least an hour or so. Then would start again fine, then die and so on.
The fuel pressure regulator is either good or bad, they're not intermittent. Very simple part and rarely fails.
Make sure the pump is getting battery voltage and has a good ground. If those are ok, stick an AC Delco pump in there and be done!
barnesto
31
06-11-2014 07:12 PM
Dirtyberguy
07-05-2009 11:09 PM
Alex01tib
03-26-2009 02:11 PM
harrymanback
09-19-2008 02:14 PM
