Go Back   Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 2nd Gen S-series (1995-2005) Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to Blazer Forum!
Welcome to Blazer Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Blazer Forum today!
Reply
LinkBack Thread Tools Search this Thread
Old 11-14-2009, 11:13 AM
stickemdano is on a distinguished road
Default Blend Door Actuator-'96 Blazer
1996 Blazer 4.3. 215,000 kms.
Replaced the DREADED blend door actuator. This job is not fun but also not impossible. Basically just had to keep pulling stuff off until I could get to it. It will take an afternoon and a bit more to complete. Had to walk away a few times and count to ten!!
I had the same 'no heat issue'. I started with repacing the thermostat. No change. Then replaced all the vacuum hoses. No change. I knew it was not the heater core, so I left that alone. Next I tried replacing the temperature control switch. No change. Then I went after the blend door actuator. A lot of people shy away from this but go ahead and do it if you have some basic knowledge and some basic tools.
I broke my hazard switch during the operation and replaced it no problem (easy fix). Now that everything is said and done, only problem I have is that the turn signals (and hazard) do not work. I checked the fuses and they are OK. Any ideas? Is there an electrical connection under the dash I may have forgot about?
Reply
Tags
1996, 95, 96, 99, actuator, blazer, blend, change, chevrolet, control, controls, door, heater, switch, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
