Blend Door control TAB Broken
Old 01-08-2015, 03:24 PM
cb_murray's Avatar
cb_murray is an unknown quantity at this point
Default Blend Door control TAB Broken
While replacing my blend door actuator (specifically, while removing the hidden forward screw), I broke one of the two square tabs on top of the blend door shaft. I tried to turn the remaining one with my fingers but was unable, so perhaps it is jammed inside the box. Has anyone been through this before?
It appears that i will have to remove the heating coil to get access behind. I suspect that the blend door itself is a dealer part.
I am holding out hope that i can think of a sneaky way to repair or modify the tab at the actuator motor, to avoid disassembly of the box.
Ideas? Thanks.
Old 01-08-2015, 06:41 PM
Don't like being the bearer of bad news, but, the entire instrument panel must be removed from the vehicle before the heater case can be removed & split apart, to fix the door. Might as well replace the heater core while you're in there. If it needs a new door, you have 2 choices: Dealer or boneyard. Depending on the year of the vehicle, certain parts have been discontinued. If you haven't had the "pleasure" of doing this job, plan on a full day of work, and you'll need an assistant for some of it.
stevesk5
07-24-2012 01:30 PM
fireye
14
02-29-2012 09:37 PM
HHimmy
08-05-2010 06:51 AM
stickemdano
11-14-2009 11:13 AM
oisinirish
05-20-2009 08:13 PM
Quick Reply: Blend Door control TAB Broken
