Blower control module on 01 blazer LS
Old 02-13-2014, 11:41 AM
gagirl320's Avatar
gagirl320 is on a distinguished road
Default Blower control module on 01 blazer LS
Ok so my heater/ac is not blowing on 1 & 2, it blows but squeals on 3 & 4, took it to the shop, they said it is a bad blower motor & resistor, BUT they aren't sure if my truck is equipped with a Blower Control Module and if it is that is additional $357.00 on top of the $381 for the motor & resistor and they want to charge $100 just to check and see if I have one... Can anyone give me any advice?
2001 Chevy Blazer 4DR, 2WD, LS
Old 02-13-2014, 11:52 AM
If it works on all 4 speeds, then the motor is at fault and the resistor is likely fine. The resistor module is responsible for the speeds and typically results in the fan not working in one or more of the speeds.
The fact that you stated you have 4 speeds means that you do not have a blower control module which would provide a variable speed output, not 4 discrete speeds.
It sounds like the shop you took it to was trying to take advantage of you instead of looking into the problem for a better estimate of costs.
Old 02-13-2014, 11:54 AM
gagirl320's Avatar
I have 4 speeds but right now only 2 (3&4) are working...
Old 02-13-2014, 12:22 PM
Sorry I missed that it wasn't working on 1 & 2 and read it that 1 & 2 work with 3 & 4 working, but a noise.
So yeah, then the resistor is bad as well. Both are fairly easy to replace. The resistor is located on top of the HVAC enclosure under the hood near the distributor. The fan is between the PCM and the HVAC housing on the firewall right near the passenger side fender.
For more information, the only time there is a blower control module is when the truck is equipped with automatic climate control. In which case, the blower control module takes the place of the blower resistor module.
Old 02-13-2014, 12:26 PM
gagirl320's Avatar
So how do I find out if I have a blower control module?
Old 02-13-2014, 06:15 PM
gagirl320's Avatar
Thanks! I do not have the automatic climate control that will save me $400!
Old 02-16-2014, 08:41 AM
lukc22's Avatar
lukc22 is on a distinguished road
I have a 98 and when I was only getting certain speeds, it was the resistor... It was located behind and underneath the glove box... If i remember correctly, it had 2 screws holding it in... easily swapped...
unpredictable1
24
01-10-2016 10:22 AM
nortonii
07-10-2011 03:09 PM
Brian123456789
12-24-2010 03:55 PM
Brian123456789
12-24-2010 03:48 PM
judgemint
11-30-2010 09:28 PM
Quick Reply: Blower control module on 01 blazer LS
