BLOWER IS STUCK ON DEFROST
I have a 96 blazer and my a/c is stuck on defrost wont blow out vents. Happened once before but worked again the next day. Now it has done it and wont go back.
RE: BLOWER IS STUCK ON DEFROST
Auto or manual climate control? For either, the modes require vacuum to the head unit to work.
Welcome to the forum!
I would advise using the search function to see if others have had the same problem as you. This one seems pretty similar and I searched for 'vacuum hvac' after some preliminary searches about A/C being stuck in a certain spot. Good luck and I hope you find what you're looking for!
its manual
I have the same problem with my 97. Except from what I am gathering, mine is just the switch.
I turn it, and it doesn't even click anymore.
maxvamp
10-31-2020 08:19 AM
MJKH84
02-22-2015 07:02 PM
KC-BodyMan
12-12-2009 09:22 PM
