body control module
Old 09-25-2009, 08:13 AM
vetteandblazerman's Avatar
vetteandblazerman has a little shameless behavior in the past
Default body control module
99 4wd 4d auto with factory fit keyless entry,more on my problem.Having had the car on a tech 2 scanner, it came up with code u1064 ,loss of communication with BCM.
Does anyone know where the the BCM is located on this truck, thanks anybody.
Old 09-25-2009, 09:13 AM
rriddle3's Avatar
IIRC, it's to the right of the accelerator pedal, beneath the radio. Not sure though.
Old 09-25-2009, 09:48 AM
ok,i think i found it, very well hidden,odd shaped black plastic box.
Now to figure out why its not communicating with the keyless remotes.
Thanks rriddle3,
Steve
Old 09-25-2009, 09:28 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Check the 10A TBC fuse in the underhood fuse block. Also taped to the harness going into the body relay block (huge connector, front of dash, your left knee (or maybe a bit more to the left) would hit it if the dash wasn't there) is a splice pack with 11 different colored wires tied together (in the schematic and diagrams they show it outside the harness anyhow) That splice pack is where all the modules tie together for communication. Diagnostics say to start there and look for a bad connection going to the offending module. (light green wire goes to the BCM)
Old 09-26-2009, 03:43 AM
Thanks for the info ronjon,at last i know which direction to go to solve this pita security
problem.
monkey23
07-04-2015 12:40 AM
ccross13126
02-05-2012 11:04 AM
ccross13126
02-02-2012 08:52 AM
rjar5
05-01-2007 10:11 PM
Halflifezr2
Engine & Internal
12-06-2004 07:32 PM
Quick Reply: body control module
