Clunk from rear when starting
Old 09-19-2007, 10:04 AM
andrewr's Avatar
andrewr is an unknown quantity at this point
Default Clunk from rear when starting
When i start my '99 blazer there is a loud clunk from the rear, what could this be?
Old 09-20-2007, 02:38 PM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
Default RE: Clunk from rear when starting
Nothing should be moving in the rear of a Blazer when it is started, other than the fuel pump pumping gas to pressurize the fuel lines. So following that line of reasoning, could it be possible that your fuel line(s) is not properly anchored to the frame and actually jerks/moves when it gets pressurized? I can't think of anything else that it could be?!?
I wonder though, could you think it's coming from the rear, but it's really coming from the front? Maybe a broken motor mount....?????
Old 09-21-2007, 11:25 AM
classic_cruiser is an unknown quantity at this point
Maybe damaged or interfering exhaust components...?
Old 09-22-2007, 10:25 AM
Dabber's Avatar
Dabber is an unknown quantity at this point
I had a new muffler and such put on a while back and recently it started the same thing. I had the better half start the truck while I was back under there and found the exhaust tapped on the shackle(or spring)when it first started. Just bent the hanger in a little and no problemo since. Something to try.
choover82
01-14-2012 01:02 PM
Foreman00081
05-22-2010 11:41 AM
mxboy96
01-05-2010 06:31 PM
ligero18
11-04-2009 12:38 PM
stephensh
09-27-2009 10:06 AM
Quick Reply: Clunk from rear when starting
