Bolt head size for 2000 LT 4x4 front shocks? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 09-21-2007, 01:33 PM
filtalr is an unknown quantity at this point
Default Bolt head size for 2000 LT 4x4 front shocks?
Posted this below in general and then saw the "post in appropriate subsection" post (oooops).
Anyway what is the proper wrench size for the front shock bolts on a 2000 LT 4x4? I fit a 3/4" on it but it seems just a bit loose - is it metric? Don't have a that big of a metric to check with... would hate to round it off as it is a bit stubborn [:'(]
[align=left] [/align]
Old 09-21-2007, 01:50 PM
Default RE: Bolt head size for 2000 LT 4x4 front shocks?
I believe it is 18mm which is ~0.746 inch... It is close enough to use a 3/4" socket, but an open ended wrench or 12pt box end wrench may be pushing it if you have to apply a ton of force to get it apart.
Old 09-21-2007, 02:27 PM
Thanks for the speedy reply - the 3/4 sockets are 6 point so I may give it a try <fingers crossed>
Old 09-21-2007, 02:35 PM
Actually, sorry, I screwed up my conversion... 18mm == 0.708" so there is a bit more of a difference. 19mm is very close to 3/4". I mistakenly typed 19mm when I converted it...
So yeah, you'll want to try and find some 18mm wrenches or sockets. Sorry for the confusion.
Old 09-21-2007, 04:24 PM
Well the 3/4 six-point worked for getting one side off -- I'm inside cooling off before putting it back on (93 degrees here in OKC today) going back for the other as soon as I'm ready
Old 09-21-2007, 10:13 PM
Got 'er done ... with only one scrape and one slightly smashed fingernail - not too bad all things considered. Also did a little recon for my next adventure - replacing the front wheel hubs (there will be a new thread on that soon). Overall the 3/4 six-points worked ok - just a little on the loose side. Those flaps protecting the engine compartment on top were a royal PITA - felt like cutting them off but instead folded them up, in and out of the way for the most part - problem was they were so brittle they nearly broke off anyway.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Whats the difference between Monroe sensi-trac shocks and monroe Reflex shocks? bigdaddykane93 2nd Gen S-series (1995-2005) Tech 14 05-08-2014 09:54 AM
U BOLT SIZE HELP!!!! 98 chevy blazer ls 4x4 ksunday1 Suspension Tech 0 06-12-2013 08:12 PM
Head bolt broke off when installing the head echo1 2nd Gen S-series (1995-2005) Tech 15 08-28-2012 08:56 PM
Will a 2000 bravada motor bolt up in my 2000 blazer?? 01Blaze218 2nd Gen S-series (1995-2005) Tech 8 10-13-2011 11:05 AM
Gas Shocks vs. regular shocks jagblazer01 Steering, Suspension & Drivetrain 3 04-16-2009 04:54 PM
Tags
1995, 2000, adjasted, blazer, bolt, bolts, chevy, forum, front, head, jimmy, remove, rounded, scrape, shock, shocks, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
