Brake & ABS dash light errors
Old 03-06-2007, 03:46 PM
frankmackie's Avatar
frankmackie is an unknown quantity at this point
Default Brake & ABS dash light errors
my 2000 blazer dash lights ("brake" & "abs") come on intermitantly. i don't have a code reader (i may buy one). short of that, what does this indicate? i checked my fluid levels and they seem good. thanks
Old 03-06-2007, 04:35 PM
JustBlaze! is an unknown quantity at this point
Default RE: Brake & ABS dash light errors
Most auto parts stores (e.g. autozone, advanced auto) will read the codes for free. It would be much easier to diagnose the issue if you can get the codes read. Also, I found a recall for the ABS System on 2000 (2WD) Blazers. You can look at the recalls on the NHTSA website:
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
I'm not sure if that has anything to do with your problem, but parts that are recalled will be fixed by the dealership at no charge to you, so its worth a shot. Hope this helps.
Old 03-08-2007, 08:46 PM
thanks
smokii
10-18-2012 07:23 AM
blazi99
06-03-2010 11:54 AM
UrlorJkron
04-13-2010 06:41 AM
megtom2
11-24-2007 10:36 AM
Daninehnj
02-22-2007 02:26 AM
Quick Reply: Brake & ABS dash light errors
