Replace the junction block battery cable to fuse box
Old 11-08-2014, 12:54 PM
StarBlazing's Avatar
StarBlazing is on a distinguished road
Default Replace the junction block battery cable to fuse box
I just replaced both my positive and negative battery cables with Delco cables. My Blazer is rust free from Florida, however the 175 amp fuse junction block under the battery tray was totally corroded where the battery cable was attached. The other side of the fuse was worse!
So I need to replace the fuse junction block and the battery cable that goes from the junction block 175 amp fuse across the front of the Blazer to the fuse block.
I am surprised I did not see more on this subject searching the forum.
This cable passes through the front area of the Blazer.
Is this easy to access by just removing the radiator cover or does it get more involved?
I need to replace the 175 amp fuse junction block also. It seems that this must be a dealer only item.
Joann
10-14-2013 10:33 AM
RoxStar33
10-09-2012 01:31 PM
Nate Chesebro
09-27-2012 09:05 PM
PhiL4x4
12-01-2010 11:20 PM
lil_blazin
05-10-2009 05:20 PM
Quick Reply: Replace the junction block battery cable to fuse box
