bucking blazer
Old 04-25-2010, 06:28 PM
creeker60's Avatar
creeker60 is on a distinguished road
Default bucking blazer
1996 blazer 4wd 5sp...misfires and bucks under normal driving speeds...acceleration and deceleration it seems to stop bucking...gas smell is noticable and exhaust pipe is black...also idon't know if this means anything but if i drive it a long distance my right lower leg can feel the heat and the the console is extremely warm
Old 04-25-2010, 06:47 PM
When was the last time a full tune up consisting of plugs, wires, cap, & rotor was done?
Also, have you cleaned the MAF sensor, EGR valve, and/or throttle body?
Old 04-26-2010, 06:42 PM
creeker60's Avatar
just done complete tune up and cleaned egr...maf sensor...and sprayed out throttle body ....also forgot to mention if i'm riding with my window down fumes are really bad and seem like its coming right through open window(just on drivers side)....also someone suggest unhooking IAT sensor...i tried it and it seem to run better for the first couple of miles and then went back to bucking again
also forgot to mention ...done pressure test...reading aroung 56#....with switch on...after letting it sit for a while it dropped to around 52#(3 minutes) but stayed at that pressure until i unloaded it
Last edited by swartlkk; 04-27-2010 at 06:14 AM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old 04-27-2010, 06:17 AM
Almost sounds like something is restricting the exhaust (clogged cat), but the fact that it resets itself is very odd...
jerjohn77
02-13-2011 08:05 PM
rodeo84u
01-19-2011 09:25 PM
creeker60
04-25-2010 04:14 PM
TBone007
03-12-2010 10:59 PM
marks_bensmom
06-01-2009 10:19 PM
Quick Reply: bucking blazer
