Burning smell underhood
Old 02-25-2010, 05:33 PM
Blazerboy1611's Avatar
Blazerboy1611 is on a distinguished road
Default Burning smell underhood
I got a wierd smell under the hood.
Smells like burnt rubber but i dont know if its the belt.
checked the belt; shows no sign of rubbing.
Any ideas?
Old 02-25-2010, 05:39 PM
Take off the lower air dam (what runs from behind the bumper to near the front axle). Look at the passenger side frame rail directly under the radiator for the AIR pump (AIR = air injection reaction which forces fresh air into the exhaust system which is supposed to improve catalytic converter efficiency). Follow the large line out of the AIR pump to where it 'T's off going to either side of the motor. Somewhere after that 'T' there will be rubber elbows. If the check valves fail in the AIR system allowing exhaust gasses into hoses that cannot handle the heat. It may be what you are experiencing.
rocktheguitarist
05-08-2011 08:25 PM
bumsinthehouse
04-22-2009 12:21 AM
Rp9110
03-03-2008 06:30 PM
aced411
12-22-2007 02:16 PM
KLBlazer07
03-11-2007 05:44 PM
Quick Reply: Burning smell underhood
