A/C Blower Problem
Old 11-05-2014, 07:47 PM
mvamobile's Avatar
mvamobile is on a distinguished road
Where is the resistor located?
Originally Posted by HcHawks09
Hey BB, glad to hear your problem was an easy fix. Mine however was not. I bought a new resistor, located it and replaced it, hoped back in the blaze, and still nothing! i was a little frusterated so i drove it up to Pep Boys to see if i could get any suggestions. All he told me was that he could run a diagnostic for $40, other than that he couldnt help me. Even more frusterated now, I went back out to the parking lot too see if i could run my own diagnostic (look to see if anything is visually out of place). I noticed that there was electrical tape on the plug that goes into the resistor. i decided to unwrap it and take a look. I thought maybe there was a short in the wire or something simple.
This is what i discovered:
the plug was literally taped to the wires! not connected at all!!!!
someone just taped it on there and called it a day!
UGH! i was SO pissed off yesterday.. I've calmed down a little bit since then though. lol
But what aggravates me is that i dont even think my resistor needed to be replaced, it didnt look fried. the resistors themself were a little discolored but does that mean it was fried? What do you think?
Close ups are attached.
OLD is on left and NEW is on right
So, I SHOULD be able to take a plug from the JY and wire it up to the existing wires correct?
The principle of the matter pissed me off...
Attached Thumbnails A/C Blower Problem-2010-04-13175407.jpg   A/C Blower Problem-2010-04-13175415.jpg   A/C Blower Problem-2010-04-13175359.jpg   A/C Blower Problem-2010-04-13172802.jpg
Old 10-04-2017, 02:41 PM
amadornav's Avatar
amadornav is on a distinguished road
Default AC blower only works on number 4
I got a 2000 Chevy Blazer 4.3 blower only works on high I check fuses and on the fuse box the fuse label HV AC 30 amp there is no power to it I replace the the resistor also replace the switch still the same any ideas?
Old 10-14-2017, 09:54 AM
jimspahr@msn.com's Avatar
Here's a great site for the GM 4.3L V6 and tells you how to test the suspect item, not just replace parts. Usually all you need is a multimeter to do it. It talks about testing the resistor and the blower motor! There is a Part 1 and a Part 2. Read and enjoy. Jim
Part 1 -GM 4.3L 5.0L, 5.7L Index of Articles
maxvamp
10-31-2020 08:19 AM
Izzy207
16
12-17-2011 03:25 PM
mightymo61
02-21-2009 07:27 PM
abickford
04-03-2008 11:54 AM
killerelfboy
01-11-2008 12:44 PM
Quick Reply: A/C Blower Problem
