camshaft position sensor replacement? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 01-26-2007, 05:34 PM
88blackzcand95blazer is an unknown quantity at this point
Default camshaft position sensor replacement?
whats up fellas, i just bought a 95 4x4 4.3 blazer a couple months ago and am trying to get it running the way i want. the check engine light just came on and az indicated that it was throwing a "po340 code, camshaft position, sensor A - bank 1 circuit malfunction". i did some research and realized that the cam sensor is in or near the dist. my question is how hard is it to access and replace?
Old 01-26-2007, 05:36 PM
Default RE: camshaft position sensor replacement?
I believe that your CMP sensor is in the same location as the later SCFI motors. If you have a hard plastic connector at the base of the distributor, then... Pull off the distributor cap, remove the rotor, line up one of the gates on the reluctor ring with the boss on the sensor. Remove the electrical connection and unbolt the sensor. Installation is reverse of removal.
If you have wires coming out to a connector mounted to those wires, then it may be alittle more lenghty...
Closed Thread
Thread Thread Starter Forum Replies Last Post
camshaft sensor and throttle position sensor. russ1609 2nd Gen S-series (1995-2005) Tech 9 01-30-2012 08:08 PM
camshaft position sensor help TheNewKid Engine & Transmission 2 09-29-2010 09:38 PM
camshaft position sensor bulletuga 2nd Gen S-series (1995-2005) Tech 3 07-26-2010 09:26 PM
camshaft sensor rob2129us 2nd Gen S-series (1995-2005) Tech 2 12-19-2007 11:03 AM
camshaft position sensor p0300 murfthesurf4 Engine & Transmission 5 11-26-2007 12:00 PM
Tags
1995, 2000, 95, bank, blazer, cam, camshaft, change, chevy, installation, location, position, replace, sensor, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
