Changing Fuel Filter on 2002 Blazer
Old 06-16-2007, 10:08 PM
sampogers's Avatar
sampogers is an unknown quantity at this point
Default Changing Fuel Filter on 2002 Blazer
Hi everyone. I am having a problem getting my 2002 Blazer to start and it looks like a fuel issue. The cheapest thing to try first is to change the filter. I was able to disconnect the lines on both sides of the old filter, but the filter is seated inside a wide black plastic ring that is also connected to a bracketholdingsome other lines on top.
For the life of me I cannot slide the filter out of the plastic ring. There does not seem to be any bolts or screws. Any ideas on how to get it out?
Thanks!
Old 06-17-2007, 04:40 AM
PSD's Avatar
PSD
PSD is offline
PSD is an unknown quantity at this point
Default RE: Changing Fuel Filter on 2002 Blazer
That plastic filter holder is a real pain. I think the first one I replaced on mine, I ended upremoving that bolton top of the ring you speek of. I think just looseningthe boltwill lighten its grip on the filter. Spraying the filter body and ring with WD-40 will also help. Mine gets a road grime coating that compounds the problem. Maybe someone else will chime in with a trick that makes it real easy.
Old 06-17-2007, 06:21 AM
DINO55 is an unknown quantity at this point
The only other trick I have for you is to lightly coat the threads on the new fuel filter with some Anti-Seize compound before the re-assembly. It will make life sweet on the next filter change.................
Old 06-17-2007, 01:07 PM
sampogers's Avatar
Thanks for you help. It isn't the threads on the fuel line that is the problem. It is sliding the filter out of the plastic ring. I didn't feel a nut on top yesterday. I will try again and see if there is one there after all.
Old 06-17-2007, 05:04 PM
Yeah, it's a pain. I found that my channel-locks twisting while I pulled on the filter made it a bit easier. WD40 also helps a bunch. There should be a 10mm bolt up above the filter.
landob123
09-27-2014 10:01 AM
bryanmine
05-04-2011 10:55 PM
busta_bird
01-11-2011 04:38 PM
nofear17bmx
01-21-2007 06:10 PM
azblazer89
07-26-2005 12:14 PM
Quick Reply: Changing Fuel Filter on 2002 Blazer
