Changing rear differential fluid
Old 04-27-2008, 08:28 PM
Ludachrls83's Avatar
Ludachrls83 is an unknown quantity at this point
Default Changing rear differential fluid
I have 80k miles on my 2000 2dr Automatic 4x4 and want to change the rear diff fluid myself. I found some good how-to's on here but have some questions.
What is the correct gear oil to use and how much?
What is the best RTV sealant to use?
I have read that you cannot use RTV sealant if you use synthetic because it will leak. Is this true?
Does anyone have any tips or things I should look out for when doing this?
Thanks
Old 04-27-2008, 08:31 PM
TripleBlackBlazer's Avatar
Default RE: Changing rear differential fluid
The answer that was provided here wasn't good enough?
Please do not post the same question repeatedly.
egbert567
10-14-2012 09:40 AM
Drew4711
10-06-2012 12:47 PM
jmaynard
21
08-18-2010 11:12 AM
tkf5651
06-02-2008 09:43 PM
98BlazerLT4x4
03-04-2008 06:00 PM
Quick Reply: Changing rear differential fluid
