Changing Thermostat on 2000 Blazer
Old 10-28-2005, 12:27 AM
Weshard's Avatar
Weshard is an unknown quantity at this point
Default Changing Thermostat on 2000 Blazer
I have not worked on a car for 20 years so things are different... I need to replace the thermostat but can't find a drain on the bottom of the radiator. Is there one? Is there another way to get the fluid down so I can replace the thermostat without flooding the drive? Weshard
Old 10-28-2005, 01:26 PM
tdannar's Avatar
tdannar is an unknown quantity at this point
Default RE: Changing Thermostat on 2000 Blazer
On my 98 4X4, the drain for the radiator is on the passenger side, on the back side of the radiator (facing the engine), not on the bottom. On my 4X4, I can only access it from the top side due to bash plate. On my 4X4, there is a drain hose connected to the drain. Nice set up, doesn't get all over the place when draining. It is a plastic drain plug that makes about 1/2 to 1 turn and stays on the radiator.
TD
toms2000blazer
12-20-2015 07:23 PM
oem95blazer
05-28-2014 03:09 AM
R134A
06-01-2010 06:21 AM
pigmak
08-14-2009 09:41 AM
CKSMartin
02-24-2005 02:39 PM
Quick Reply: Changing Thermostat on 2000 Blazer
