injectors?
injectors?
every morning when i start my car i noticed it takes longer to start then usual. there is no real performance difference, but i want to get it to run dependable. i think its fuel delivery but not sure.
RE: injectors?
The first part of any fuel problem diagnosis is a fuel pressure test (key-on/engine-off) followed by a leak down test (key-off - monitor fuel pressure over the course of 30 minutes). You will need a fuel pressure gauge. The fuel pressure test port is located behind the throttle body on the fuel feed line.
