Clock stays on when key turned off
Old 02-09-2008, 06:54 PM
sidewheeler's Avatar
sidewheeler is an unknown quantity at this point
Default Clock stays on when key turned off
I had the fuel injector system replaced. When I picked up the car (95 blazer 2dr v6) I noticed that the clock was on even though the key was not in. I mentioned this to the repair shop and they said that they didn't do anything to the electrical system. I thought that maybe it was just a one time thing. well after a few days I started thinking that if the clock is on then other electrical items must also be on and draining the battery. I checked the fuse panel on the drivers side at the door and determined that one of the fuses controled the clock and removed it. this fuse also controls the memory of the clock as well as the radio, so now every time I turn the key off I loose the time and radio station. Is there a delay switch that has gone bad and where is it
Old 02-09-2008, 07:35 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: Clock stays on when key turned off
You might have a faulty door switch somewhere. I assume the clock is staying on when the key is removed and the door has been opened. If the door has not be opened this is normal, just make sure when the door opens the clock should go off.
Old 02-10-2008, 12:11 AM
Thanks lenny
The clock stays on all of the time. when you come back to the car after it sets all night the clock is on. I thought there was a relay switch that turned off the clock when you turned off the key.
Larry
abig84
01-08-2013 04:13 PM
Aaron121782
05-30-2012 08:07 PM
Mr.T
01-19-2010 09:24 AM
Irish10Hockey
12-04-2008 12:48 PM
speakerwire
09-19-2008 02:25 PM
Quick Reply: Clock stays on when key turned off
