Clunk when turning right
Old 02-02-2012, 07:05 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
Default Clunk when turning right
When i turn right sometimes sharp, sometimes not as sharp but about half turn there is a loud clunk from under the front driver side, sometimes when i brake. I also feel a "shift" in the truck a little bit. I just replaced the outer tie rod on that side (was bad anyway) and lower ball joint on other side due to it squeaking. When i look at the wheel it moves with the popping noise, it's hard to tell but it either is bringing the bottom in or the back of the wheel in, but immedeatly goes back. Please help, this is driving me nuts...
And when in the air the wheel doesn't budge when pulled, pushed, or anything
Old 02-02-2012, 07:07 PM
xgiovannix12's Avatar
get someone to turn the steering with you under the truck you should pin point where its coming from
from a wild guess it sounds like a ball joint
but id rather find the problem then guess right ?
Old 02-02-2012, 07:13 PM
it doesnt do it when sitting still, and being under the truck while in motion proves challenging...
Old 02-02-2012, 07:37 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
id check the upper and lower a arm bolts make sure there tight also check the shock bolts i had one loose and it made a clunking sound. if it clunks when you turn sharp it could be a CV joint and that's normal
Old 02-02-2012, 08:00 PM
I'll check the bolts, The CV axel would make sense but i only hear the clunk once. My past experiance is it does it repeatedly.
Old 02-02-2012, 08:21 PM
97cherryblazer's Avatar
97cherryblazer will become famous soon enough97cherryblazer will become famous soon enough
Well what fun are you!! lol
But i would also guess the CV. yes it can make a continuous clunking sound but it can also make one. i would look at the boot to see what shape its in first. if its cracked or theres a bunch of grease around it then that might give you a hint also
Old 02-02-2012, 08:26 PM
there is grease being splattered around, Looks like when they spin it is slung off. When I tug on them they are pretty solid. With grease like it is they will need replaced soon anyway.
Old 02-02-2012, 08:53 PM
scottl1346's Avatar
the grease maybe from the upper ball joint not the cv boot. check the boots for tears if there aren't any then there prob good.
Old 02-02-2012, 09:49 PM
dont seem to be tears in the boots for the ball joints. The grease is defiantly coming from the CV axel's boot. I heard something about the torsion bar crossmember casueing a symptom like this. Anyone know how to tell if it is that or not?
Old 02-02-2012, 10:26 PM
crawl under the truck and try to push the cross member up if theres play that means the mounts are shot
Quick Reply: Clunk when turning right
