Clunking in rearend
Old 01-14-2005, 01:24 PM
BlazerLS95's Avatar
BlazerLS95 is an unknown quantity at this point
Default Clunking in rearend
Clunking in rear of vehicle. Also feels as if rear wheel is loose when making a turn. Put up on jacks nd turn wheels by hand with little or no noise. Put in gear and the clunking returns. Thanks
Old 01-15-2005, 06:47 PM
hyperlite_rider is an unknown quantity at this point
Default RE: Clunking in rearend
Well, if it's anything like what happened to my blazer then I can tell you. I have been hearing a clunking noise from the front of my car for about a week, and it sounded like the front like wheel was loose. I checked the wheel a couple of days ago, but it was fine. Today I looked under the front end, and I discovered that one of two clamps holding an anti-sway bar or something was broken, and this sway bar was hitting the frame every time I went over a bump. It's an easy fix, I just didn't know what was wrong at first. I don't know exactly what could be making your sound, but it might be something similar so you should take a closer look.
Dallas1970
02-22-2019 05:05 PM
drogg1
01-23-2010 06:41 PM
lt170chevelle
12-14-2009 12:18 PM
DFINE160
12-07-2009 12:17 PM
countilaw
02-21-2008 08:44 PM
Quick Reply: Clunking in rearend
