Courtesy light mounting location
Old 12-07-2008, 04:08 PM
Ted's Avatar
Ted
Ted is offline
Ted is an unknown quantity at this point
Default Courtesy light mounting location
So I spent the afternoon replacing the combo switch on my daughter's 98 Blazer. A couple of great tips from this forum made the job easier and saved my hunting down some sockets for the single external torx screw.
Anyway, when I remover the filler panel, a courtesy light dropped down. As I was putting things back together, I looked and looked for a mounting location, but couldn't find one. This is, of course, the driver's side.
Can anyone tell me where that courtesy light should mount?
Thanks.
Old 12-07-2008, 06:33 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: Courtesy light mounting location
should be a 7mm bolt holding it in place, under the dash-look up to the right of the e-brake handle, above your foot brake, mounted in the darker colored plastic under the actual dash. There should be a void, cavity where you can see the spot. JP[&o]
Bry85
03-13-2012 08:46 AM
Thogert
07-13-2011 06:02 AM
1997 red blazer
02-10-2010 01:10 PM
skybolt31
11-29-2009 03:10 PM
NTL1991
12-29-2008 03:31 PM
Quick Reply: Courtesy light mounting location
