? dead battery
Old 10-15-2007, 08:30 AM
drperry's Avatar
Default RE: ? dead battery
When you turn the key to run, if you don't start it right away, you should hear the pump cycle, as long as your window or door is open...
You could always try boosting the Blazer, lol.
It could also be coincidental fuel pump failure... AsI understand it, the pump isn't always a long life product on these things...
  #22
Old 10-15-2007, 10:23 PM
silentknight's Avatar
silentknight is an unknown quantity at this point
Cannot hear pump cycle, I laid under fuel tank and had wife put switch to RUN. Also checked pressure in line (no gauage, pressed something into valve while trying to crank, nothing came out). So, guess I will replace FP this weekend. Any advice / how -to as far as dropping fuel tank etc?
  #23
Old 10-15-2007, 10:32 PM
rriddle3's Avatar
Here's one of the latest threads on that matter:
https://blazerforum.com/m_100227/tm.htm
  #24
I would test for power at the pump before replacing it. Would suck to do all that work and find out that the fuse or relay failed...
  #25
Old 10-15-2007, 10:58 PM
When getting fuel out of tank, was reading another post stating something about a ball check valve in fill outlet, preventing siphoning. ???? Is this the case?????
  #26
Old 10-17-2007, 12:19 AM
Could it be anti-theft system has kicked in for some reason and disabled fuel?
Just trying to cover all bases.
  #27
Old 10-19-2007, 03:25 AM
Just another quick question, where is the ICM located? Passenger side of motor on top behind alternator or elsewhere?
  #28
Old 10-19-2007, 05:46 AM
The ICM is located between the throttle body and the passenger side valve cover. It will have a silver heat sink on it with an electrical connection. Most autoparts stores can test the coil and ICM.
  #29
Old 10-21-2007, 11:27 AM
Just wanted to let everyone know it was the fuel pump. Replaced it yesterday & Blazer runs fine again.
Thx to everyone who posted suggestions and comments, ya'll were invaluable!
  #30
Old 10-21-2007, 11:50 AM
Glad you got it all fixed back up!
94s10blazin
08-10-2013 01:00 PM
twilkinson3
11-10-2009 06:26 PM
Zasder
11-14-2007 04:44 PM
rriddle3
08-26-2007 04:38 PM
brownblazer
09-12-2005 06:55 PM
Quick Reply: ? dead battery
