does anyone have a vacuum line diagram for a 2000?
Old 08-04-2014, 11:18 AM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default does anyone have a vacuum line diagram for a 2000?
im not sure if i have a leak, 4wd, hvac and cruise all work fine. but i have a revving problem during startup and was advised to see if any lines are brittle/ leaking, i just had a few replaced mostly on the drivers side of the engine, i know theres some under the battery tray,
also what size lines do i need?
Old 08-04-2014, 03:24 PM
swells87's Avatar
swells87 is on a distinguished road
I would love to see a full vacuum diagram as well anybody know of a good place to find one?
Old 08-05-2014, 10:53 PM
aa21830's Avatar
aa21830 is on a distinguished road
If your HVAC and 4WD work, then it's unlikely you have vacuum leaks. And FWIW, vacuum has nothing to do with cruise control.
If you want to look at the vacuum lines, check out this page and look at the links for transfer case switches and 4x4 troubleshooting. The vacuum diagrams for the 1996 Sonoma and the 2004 Blazer are the same, except the vacuum reservoir is located inside the fender well for the newer vehicles (including your 2000).
Old 08-07-2014, 12:05 PM
lilblazer's Avatar
lilblazer is on a distinguished road
I would also like to see one of those. The guy who I bought my 2000 Blazer off of changed the engine and failed to connect about a half dozen hoses. It'd be nice to know where they all go.
Old 05-14-2016, 07:07 PM
Jeff Long's Avatar
Jeff Long is on a distinguished road
I have the same problem. Before I bought the Jimmy they had put a new Manifold Gasket installed. Now I have found a vacuum hose without a home. I have a whistling sound coming from underneath the pass/side. The hose has a collar on it
vantoine
10-11-2010 08:41 PM
slickvic863
07-16-2010 08:33 PM
DATEGGY39
09-16-2009 11:58 AM
apoch
02-19-2008 11:04 AM
USMaverick101
10-20-2006 06:46 PM
Quick Reply: does anyone have a vacuum line diagram for a 2000?
