Electrical issues
Electrical issues
Hey i was wondering if any of you guys have experianced a problem with the electric seat and mirrors? as in they wont work at all, is this a common issue? is there a common problem between the two? i know all the motors wouldn't have gone out at the same time, so is this a fuse issue? or perhaps a connection to the fuse panel?
The common denominator of the two is fusible link "D". If that link is open there are several things that will not work: Keyless entry, both outside mirrors, interior light module, driver information display module, taligate lock, rear dome light, data link connector, and aux power outlets. If any of those items work, the fusible link is ok, and you should check fuses and circuit breakers. There has been a problem with wiring connectors under the carpet on the driver side, (under drivers feet area), power feed for the power seat, orange with a black stripe wire.
JoSHN
09-14-2012 04:56 PM
rick nielsen
Engine & Internal
10-14-2007 03:41 AM
WisdomRacing
07-01-2007 09:29 PM
blazinDJ420
05-21-2007 03:44 PM
