DTC codes on 99 Bravada
Old 10-31-2014, 05:31 PM
sky_blazer's Avatar
sky_blazer is on a distinguished road
Default DTC codes on 99 Bravada
just got my truck back from intake gaskets from my local craigslist mechanic (which i will never do again) i got some DTC and me SES light on
P1345=camshaft and crankshaft positions are out of time
P1404=EGR stuck open
obviously the distributor was removed so im thinking maybe its off so i need to know how to make sure its set on properly
also the idiot told me he removed and cleaned my EGR as a courtesy to me (ya courtesy my ***) can anyone snap a picture of the EGR so i can see the correct orientation of its placement? thinking its on the wrong way
Old 10-31-2014, 05:40 PM
P1345 means the distributor was not installed correctly. It's off at least one tooth, and it could be off in either direction. This link explains how to time it correctly: https://blazerforum.com/forum/tech-a...-timing-24373/
Take care of that first, then clear the codes and see if the P1404 returns. Let us know and we can help you with that.
Old 10-31-2014, 06:27 PM
sky_blazer's Avatar
thanks im gonna tackle it tomorrow im pretty beat tonight
Old 11-01-2014, 12:34 AM
DimeBlazr's Avatar
DimeBlazr is on a distinguished road
As the captain says, 1345 is the distributor out of time for sure, the egr valve can be a couple things, it could be that its on backwards, it could have been wrecked by cleaning or there could be an electrical problem like damaged wiring or a bent pin or loose female terminals in the plug. The code indicates a pintle position error, this requires a 5 volt reference and the sensor in the egr has to send a specific voltage back. Check out this page for some general info on EGR testing
Part 1 -How To Test the GM EGR Valve -Buick, Chevy, Olds, Pontiac
Old 11-01-2014, 06:56 AM
sky_blazer's Avatar
thanks Captain Hook once again you saved the day got the distributor installed correctly as per the link. when i had it off i saw paint marks the guy put on it to install it in the same position guess he didnt know how to do a Vortec distributor lol
anyway for s/g's i flipped the EGR around (plug is on the left side now) and took her for a ride and no SES light no codes can anyone confirm i have the EGR on right?
Old 11-01-2014, 06:10 PM
The EGR electrical connector should point to the passenger side, (right side) of the vehicle.
Glad you got her fixed, thanks for posting back. Might want to find a new "mechanic"
Old 11-01-2014, 06:46 PM
sky_blazer's Avatar
yep already started the search for another one and no more craigslist mechanics..this guy said he was state certified too LMFAO
upon doing more research i realized i could probably have done the job myself
abadinalbany
04-16-2011 11:31 AM
bigjoewebb
01-27-2009 09:36 AM
Ron9919
10-30-2007 10:16 AM
mikeesho1
10-26-2007 12:31 AM
drperry
07-04-2007 04:25 AM
Quick Reply: DTC codes on 99 Bravada
