07-08-2012, 07:55 PM
ECM / PCM fuse location ??? 95 Blazer
Hello everyone.. I have a 1995 Chevy blazer 4w drive 5/95 ..
Can someone tell me where the fuses for the ECM or PCM are located? I have a scanner and was going to scan my blazer but it says there is no response from the Blazer .. So I'm thinking it could be a fuse. My check engine light does not come on even when I first put my keys in and turn to start all Lights in the dash come on but I see no check engine light .. What would cause this? Is it the Fuse...
07-08-2012, 08:18 PM
I know some are under the hood in the box over the driver's fender well in my friends 97 jimmy so I'd start there, & plz don't double post just makes for a cluster **** & does mean you get an answer any faster. good luck on ur issue.
__________________
How to solve any problem with a vehicle in 2 steps. 1.) Get a hammer. 2.) state problem & add .. So I hit it with a hammer. Ex. "My Ford broke down again, so I hit it with a hammer!"
"My BFHs double as WMD or instruments of precise adjustments. Depending on the application"
Current Project: Making the Jeep Road worthy
1972 Wagoneer -> Build Thread
07-08-2012, 09:28 PM
1995 was a transition year, 2 different fuel delivery systems and 3 different OBD systems were used, (one of the reasons Olds did not produce Bravada in 1995).
Which data link under the dash do you have?
Also, is the PCM mounted on the passenger side inner fender on top of the coolant reservoir?
Make sure you check all fuses.
__________________
I changed my car horn to gunshot
sounds. People move out of the
way much faster now.
07-08-2012, 10:19 PM
Are the Fuses at the computer pcm or Where ? The Check engine light does not even come on when i turn my key ..would that cause that to happen?
07-08-2012, 10:20 PM
Quote:
Sorry didn't mean to double post..
07-08-2012, 10:21 PM
Quote:
Originally Posted by miztic2u
are the fuses at the computer pcm or where ? The check engine light does not even come on when i turn my key ..would that cause that to happen?
eobo / obdii
07-10-2012, 04:09 PM
If a fuse is blown, the check engine light and data link connector could both be inoperative. There may or may not be an underhood fuse panel on yours. If there is, it's on the driver side close to the radiator support, in plain sight. Check both terminals of each fuse in both fuse panels.
__________________
07-10-2012, 05:37 PM
eobo / obdii
Mine Check engine light doesnt come on either
Tags
07, 10, 1995, 95, 97, blazer, chevrolet, chevy, ecm, fuse, jimmy, location, onchevy, pcm, pcmfor, sale, schematic  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
