Egr dtc p1406
Egr dtc p1406
1995 Blazer 4.3l with 110k (rolled over to 110k this weekend)
Over the weekend, we did a two day 1,000+ mile round trip to St Louis and back home. Near the end of the trip, the engine started idling noticeable strange (up and down). Finally, the CEL come on. Scan Gauge showed DTC P1406 which relates to the EGR.
So, from what I've read in the Haynes (I have nothing better), it appears just a simple cleaning should solve the issue.
Or, is this something far more complex?
Agreed. Here is some additional info about the P1406 code
P1406 Chevrolet - EGR Valve Pintle Position Circuit
Possible causes
- Faulty Exhaust Gas Recirculation (EGR) valve
- Carbon blockage of the pintle
Tech notes
The P1406 code means that the EGR valve is 10% of the expected position by the Powertrain Control Module (PCM), usually caused by carbon built up in the EGR valve. Start by cleaning the EGR valve.
When is the code detected?
The EGR pintle position was ±10% of the expected position.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
P1406 Chevrolet Description
The Powertrain Control Module (PCM) determines that the EGR valve is stuck open if the actual Exhaust Gas Recirculation (EGR) position and the learned closed EGR position vary by more than a predetermined value. The PCM tests for a stuck valve when the desired EGR position is at 0%. The PCM commands the EGR valve to 100% during certain driving conditions in order to clear a possible restriction from the EGR valve if the PCM determines that the valve is stuck open.
Possible causes
Tech notes
Possible symptoms
ESKYMOPACK
01-21-2015 04:11 PM
96jimmyslt4x4
10-02-2011 05:37 PM
Colby 04
01-11-2010 11:05 PM
dustenwolff
05-27-2009 07:31 PM
