EGR valve location on '95?? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 05-28-2007, 09:47 AM
gizwilly is an unknown quantity at this point
Default EGR valve location on '95??
Hi:
I've got a 95 with the Vortec v6. I'm gonna try to clean the EGR valve on it today, and am wondering if anyone can tell me it's location on the engine?
Thanks!
Old 05-28-2007, 10:09 AM
lastcoupe is an unknown quantity at this point
Default RE: EGR valve location on '95??
It's in the front of the intake manifold, below the throttlebody. It's round, looks kinda like a small soda can, and has an almost triangular-shaped base, that's held on with 2-8mm screws with 10mm hex-heads. Before you take it off, the aftermarket makes a gasket with a screen inbedded in it to prevent carbon deposits from getting into the pintle again.
Old 05-28-2007, 10:40 AM
Thanks for the reply.
I've got the new gasket with the screen.
The valve looks like it may be a bit tough to get to.....any special advice or tips there?
Thanks!
Old 05-28-2007, 10:57 AM
The only advise I can give is the proper tools, I know most people don't have it, but a 1/4" drive 10mm swivel socket and a 10" extension works great for this application. Sorry, but that's what I would use.
Old 05-28-2007, 05:03 PM
UPDATE!
Completed the R/R on the EGR.
Lastcoupe......thanks for the advice on the tools....I went to SEARS and bought them.....and they were PERFECT for the task. My regular tools would have been tough to work with in the tight space....if not impossible. Thanks again! [sm=hail.gif]
What I found was a BB sized hunk of carbon holding what I assume is the "pintle" on the EGR open.[sm=boosign.gif]
Popped it out.....sprayed carb cleaner everywhere I could...cleaned that up....cleaned the old gasket off and reinstalled the EGR with a new "upgrade" gasket with screen.
Problem Solved!
Thanks Lastcoupe, Hillbillyinohio, and Kyle.[sm=icon_cheers.gif]
You guys RULE!
Old 05-28-2007, 05:09 PM
You guys RULE!
No Problem!..Glad to hear you got it fixed!
Thank god for specialty tools right?!
Old 05-28-2007, 05:16 PM
Glad to hear!!. Yes, i got a thanks in an actual techinical section other than the A/V section!! WHOOO!!![sm=americanasmiley.gif]
Old 05-29-2007, 10:48 PM
Congrats! both to gizwilly and hillbillyinohio!
Old 08-09-2008, 03:55 PM
Kingswede is an unknown quantity at this point
where did you get the replacement gasket with the filter?
Closed Thread
Thread Thread Starter Forum Replies Last Post
location of the egr valve Kyle Wood Engine & Transmission 8 03-11-2013 08:45 PM
EGR Valve and Proportioning Valve IndianaBlazerGirl 2nd Gen S-series (1995-2005) Tech 5 09-06-2011 07:22 PM
EGR Valve Location? Rottidog Engine & Transmission 4 01-09-2010 11:32 PM
EGR VALVE LOCATION USMaverick101 General Tech Help 5 10-06-2006 09:32 PM
location egr value 94 blazer khalid_20879 1st Gen S-series (1983-1994) Tech 6 12-28-2005 09:43 PM
Tags
1500, 1995, 2004blazer, 2007, 95, blazer, chevy, clean, egr, installation, location, replacement, silverado, v6, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
