Emergency Brake Won't Disengage
Old 02-08-2014, 04:18 AM
CanadianaBlazer's Avatar
CanadianaBlazer is on a distinguished road
Default Emergency Brake Won't Disengage
Tonight i engaged the e-brake and now it won't disengage! I reversed it to try and get it moving while pulling the release in case it was stuck and it changed a but .. i have a bit of forward motion. How do I get this damn thing to disengage!
Old 02-08-2014, 01:30 PM
Twip's Avatar
Canadian, you will need to take the lower dash panel off. get a good flashlight and take a look under there where the parking brake pedal is. you should see the cable at the top that comes from the release handle. if you look carefully, you will see where the cable hooks up. its a small "tab" that holds the cable end in place. if you pull on that, careful not to let the pedal smash your arm, you should be able to release your parking brake.
Old 03-27-2014, 06:53 AM
green97blazur's Avatar
green97blazur is on a distinguished road
maybe its frozen????????
99blzr
03-12-2018 11:54 PM
CanadianaBlazer
01-22-2016 05:50 PM
218persuader
23
10-09-2009 07:24 AM
misfit
06-15-2007 08:08 PM
GMdesigner
05-20-2007 11:20 AM
Quick Reply: Emergency Brake Won't Disengage
