Engine Temp Gauge Not Reading
Old 02-06-2013, 07:25 PM
ssmith5399@nc.rr.com's Avatar
ssmith5399@nc.rr.com is on a distinguished road
Question Engine Temp Gauge Not Reading
I had an overheating problem in my '97, found one bolt on the thermostat housing had stripped out. Removed the intake manifold(s), replaced all the gaskets, re-tapped the bolt hole, then re-installed. Put in new coolant tank, new radiator, new thermostat, new temperature sensor, the works (even a new cap).
All of the connectors, and there are quite a few, are back on and snug.
Ran it a few miles and the temp reading won't budge above 100. Changed the thermostat again and the temp sensor again, still no reading. The upper hose is good and hot but the lower hose is lukewarm at best. Heater hoses are hot and heat is working. No symptoms other than reading 100 on the gauge.
Ideas are welcome !!!
Old 02-06-2013, 07:37 PM
thundergod66's Avatar
thundergod66 is on a distinguished road
maybe the temp sensor...
Old 02-06-2013, 08:40 PM
cleburne red's Avatar
There are two temp sensors, at least on my '95. One by the thermostat is for the engine's computer to determine fuel trim, etc. The one in the driver side head goes to the gauge. If you have access to a scan tool that will show live data, it can show you the temperature that the computer is seeing.
I would suggest thermostat stuck open, that happened to me. I never could get that thing to reach operating temperature! But since you've replaced it twice, I would rule that out.
Old 02-06-2013, 10:13 PM
You guys are brilliant !
I found the sensor on the driver's side head and the wire connector had popped loose.
I'm back in business and eternally grateful. Sending a cold one your way...
WalkGood
13
06-13-2012 10:39 AM
das96blazer
18
03-09-2011 05:21 PM
zakm0n
01-09-2011 07:31 PM
bertrenolds
12-19-2008 07:45 PM
ant2297
09-28-2008 07:40 PM
Quick Reply: Engine Temp Gauge Not Reading
