Oil pressure drops to 0 on turns
Old 06-29-2010, 09:01 AM
sh1520's Avatar
sh1520 is an unknown quantity at this point
Post Oil pressure drops to 0 on turns
Have a problem that started a couple days ago. I was coasting down a hill doing about 45-5-mph with my foot OFF the gas. Noticed my 'check gauges' light come on. I saw the oil pressure gauge at ZERO! I put my foot on the gas and it went back up to normal-or 40 on the gauge. Now it happens if I'm slowing to go to a stop, or turning. Whats the problem? How do I rectify this? Thanks all!
Old 06-29-2010, 09:13 AM
You really should try to verify the factory electronic gauge with a mechanical gauge.
Old 06-29-2010, 10:09 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
I would check my oil level first. Then look for leaks at the sender. It's usually located at the back of the rngine on top next to the distributor.
Old 06-29-2010, 02:00 PM
vandelayindustries's Avatar
vandelayindustries is on a distinguished road
This. The electric sending units are notorious for failure.
Old 06-30-2010, 01:33 AM
4x4BlazerZR2's Avatar
4x4BlazerZR2 is on a distinguished road
Finally, a thread I can help with! You need to check your oil level immediately. It has been my experience that you (and I) are approximately 3 quarts low when this occurs. Also, if I'm not mistaken, when you turn to the right, the gauge goes to zero as well.
Old 10-04-2010, 01:42 PM
blazinloud's Avatar
that sounds bang on, mine did the exact same thing
c40788
03-23-2014 08:52 AM
abig84
14
06-07-2012 04:21 PM
RyansChevy
19
04-13-2011 06:42 AM
new2blazers
07-24-2010 03:59 PM
rooster
06-07-2007 08:40 AM
Quick Reply: Oil pressure drops to 0 on turns
