Ex. Manifold Alignment new Long Block
Old 06-21-2013, 06:12 PM
cferry7's Avatar
cferry7 is on a distinguished road
Default Ex. Manifold Alignment new Long Block
1995 GMC Jimmy SLT 4 X 4 4.3 L
I have just partially installed my ( original ) OEM Exhaust Manifolds onto my "new" Remanufactured Long Block.
The Manifold Bolt Holes for # 5 and # 6 Cylinder's Exhaust Ports are slightly off in alignment.
Alignment Measurement difference ( approx. 2/16 in. ) is severe enough that this is
going to require to bore oversize two bolt holes in ea. Exhaust Manifold.
suggestions ... anyone been in this situation . . .
Old 06-21-2013, 07:30 PM
cferry7's Avatar
Can not beleive the head bolt spacing can be that far off that I need to bore the
original equipment Exhaust Manifold ?
Can the fact that it is not fully assembled with bolt threads still on sides of the
Exhaust Manifold bolt holes - ( ie.) the difference in spacing between bolt threads hitting the sides of the bolt holes ( partially assemble ) vs only the sleeve of the
bolts hitting the sides of the Exhaust Manifold bolt holes ( fully assembled ). ?
Yes - Bolt threads are slightly thicker in diameter than the bolt sleeves which
extend from the bolt head to the threads.
Old 06-23-2013, 03:59 PM
cferry7's Avatar
Default linkback thread !
Found the following thread which answers my question / concern.
Link : https://blazerforum.com/forum/2nd-ge...d-issue-74794/
youngsm1980
07-25-2015 05:35 AM
braxx
03-08-2015 11:18 PM
blazen_red_4x4
10-13-2014 12:39 PM
cferry7
03-19-2014 03:26 PM
lil_blazin
05-10-2009 05:20 PM
Quick Reply: Ex. Manifold Alignment new Long Block
