Floor Heat
Old 01-29-2007, 12:40 PM
jetrider's Avatar
jetrider is an unknown quantity at this point
Default Floor Heat
I have 2000 Chevy Blazer LT; currently I am having a problem I'm hoping someone might recognize. I am getting heat with no problem, and it goes where directed: defrost, vents, etc...the only place I can not direct it is to the floor, no matter what is selected. Any help is appreciated.
Old 01-29-2007, 02:00 PM
alamantia's Avatar
alamantia is an unknown quantity at this point
Default RE: Floor Heat
sounds like the rod may havefell off the actuator
Old 01-30-2007, 01:08 PM
jetrider's Avatar
How do I check and repair that? Any chance it's a vacuum line?
Old 01-30-2007, 01:11 PM
jetrider's Avatar
Actutor appears to attached and working properly. Found that behind the glove box.
Old 01-30-2007, 01:29 PM
alamantia's Avatar
did you check for vaccume while you were in there, try pulling the line off (may be a clear elbow slip fit) and moving the heater controls and see if you get suction. May even be your heater controls, always good to try and isolate it by the cheapest fix first
Old 01-30-2007, 04:39 PM
jetrider's Avatar
Vacuum is good I have suction, actuator does move when a selection is made.
Old 02-01-2007, 11:37 PM
rinkrat1963's Avatar
rinkrat1963 is an unknown quantity at this point
I just encountered this exact problem with my 98 S10 Blazer.
Old 02-02-2007, 11:58 AM
I just found out what's up with floor vents on my 98 Blazer. The flapper inside the air box under the dash is broken. All the actuators were working fine. So I took a mirror and looked inside the box from underneath the dash. The flapper pivots on a rod inside. It looks like the rod broke. I think I have to remove the air box to split it. So I guess I will have no heat this winter. Bummer.
jetrider, I hope yours isn't this problem. This looks like a nightmare to fix.
Old 02-20-2008, 10:35 PM
TheJuicer's Avatar
TheJuicer is an unknown quantity at this point
Same problem here. I can change from vent to defrost etc. But it won't go to the floor, it takes a couple seconds and then blows pretty strong through the defrost vents. I do have vacuum in the red and blue lines going to the actuator and it does move when setting to the defrost. But nothing moves when setting it to the floor. Does this mean bad actuator? It also snaps pretty hard when goingto defrost. Linkage looks good and no problems there. How do I know it's not a broken diverter flap in the vents. Are there signs?
Thanks!
1998 Blazer 4x4 4.3L 155,000
*LOCKED* Please do not spread posts around in different sections. Keep all details in one area to avoid confusion. Anyone wishing to reply to this can do so here: 1998 Blazer heating
Thanks, TBB.
TheJuicer
121
10-26-2017 07:39 PM
reed2003
06-16-2011 07:15 PM
new67rs
02-21-2007 10:56 AM
chrissy
12-04-2006 03:23 AM
guywm25
10-11-2006 10:14 AM
Quick Reply: Floor Heat
