front to rear brake line
Old 01-30-2010, 06:28 PM
dabshre's Avatar
dabshre is on a distinguished road
Default front to rear brake line
how do i start to replace the front to rear brake line on a 96 chevy?
Old 01-30-2010, 06:45 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
first did you check to see if they make a preformed line.
Old 03-25-2011, 07:43 PM
chgibson@fuse.net's Avatar
chgibson@fuse.net is on a distinguished road
I'm about to do a intake manifold gasket job on my 03 S10 blazer 4.3. Anyone have any advice on how to remove the fuel lines and to mark the distributor. Marking the distributor for the correct engine timing. Thanks advice well appreaciated.
Old 03-26-2011, 12:07 AM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
For the fuel lines, check the under hood fuse box and look for the fuel pump, take it out and don't forget what side goes what way , try to start it and for like 10seconds after it dies(this removes all the fuel pressure) replace fuse and then dont forget to disconnect battery For the line its a bit of a tight spot, get a short wrench or a cheapy and cut it to length , sorry forgot what size.
For the Distributor get a straight edge and mark on firewall, I used a metal socket holder, simple and multipurpose.
Xavier
04-11-2014 11:49 AM
wisowebs
12-26-2013 06:58 PM
elkram
05-28-2013 05:34 PM
dj00140
03-02-2011 08:52 AM
gman
12-30-2010 05:24 PM
Quick Reply: front to rear brake line
