fuel pressure regulator?
Old 03-28-2008, 10:33 PM
firemansc32's Avatar
firemansc32 is an unknown quantity at this point
Default fuel pressure regulator?
What is the best way to test if the fpr is working properlyon a 2000 4.3L. I believe it is the reason my blazer has trouble starting.
[align=left] [/align]
Old 03-28-2008, 11:23 PM
rriddle3's Avatar
Default RE: fuel pressure regulator?
Connect a fuel pressure gauge to the schraeder valve on the fuel inlet line above the engine, turn the ignition key to 'on' and the pressure should be ~51-62psi. Turn the key off and watch the gauge. The pressure should not drop more than ~2-3psi. If it does, you have a bad FPR. If the reading continues to drop over the next few minutes, you have a leak in the lines inside the upper manifold.
Old 03-29-2008, 12:57 PM
Thanks rriddle3. I guess I get to start tearing apart the upper manifold now.
Terje
11-04-2017 08:19 AM
vifa84
07-07-2007 01:58 PM
jr9880
02-08-2006 07:08 AM
jlinder
08-21-2005 11:08 AM
Quick Reply: fuel pressure regulator?
