96 blazer 4wd front skid plate question
anyone know the bolt size that holds the front skid under the oil pan on. does it use the same size as the one under the trans? My bolts i guess came loose and dropped the skid in the middle of the trail didn't know till my second time around when i saw it laying in the middle of the trail lol.
go to lcm truck they got the original bolts for it
Edit: Nevermind, read that wrong.
guess i can just pull out of the other skid plate and see if it works and if it does go match it up
For the front I believe it's 7-1.5 or 7-1.25 cant remember what the threads were. Use class 8 bolts also. Or you can call a chevy dealer and ask for the bolt sizes, that's what I did. But getting the bolts in the holes is a pain because they are usually full of gunk. The bracket bolts are different as well. Atleast on mine they were. Mine were 8-1.5
Hope this helps if you haven't already got it on.
Doubletap308
10-30-2009 10:06 PM
