Fuel Sending unit
Old 02-07-2008, 11:19 PM
MHPrior80's Avatar
MHPrior80 is an unknown quantity at this point
Default Fuel Sending unit
hey all my fuel sending unit is bad..my gas gauge keeps floppin all over...and i have a quick question , well 2 actually.
1. Do those new sending units that r on ebay really work?
2. how difficult of a job is it to replace my old one with a new one?
i know the tank needs to be removed..and all that just wondered how difficult it really could be. thanx in advance
Old 02-08-2008, 08:53 AM
rriddle3's Avatar
Default RE: Fuel Sending unit
On your year model I believe the fuel pump and sending unit only come as a one piece item. If you go for the cheap one you'll wind up replacing it sooner than a genuine GM pump. As for dropping the tank, there are a lot of threads on here explaining how to do it.
Old 02-08-2008, 09:32 AM
I think there is a separate sending unit available for you. The cost is not that bad, but the labor is the same as replacing the full pump.
Item Price Core Total
ACDELCO Part # SK1186 {#19121293}
SENSOR KIT,FUEL LVL 4 DOOR; w/o SENDER,ROBUST FUEL SYS (K53)
$77.79 $0.00 $77.79
ACDELCO Part # SK1188 {#19121300}
SENSOR KIT,FUEL LVL 2 DOOR; w/o SENDER,ROBUST FUEL SYS (K53)
$82.79 $0.00 $82.79
Now those prices are probably pretty old, but they are still be valid PNs.
Old 02-08-2008, 08:55 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
YES, Kyle is right, but if you have higher miles, and have not replaced your fuel pump, you might want to consider just replacing the whole assembly. My fuel gauge has been acting up now foe 3 years, and I am just waiting to replace the pump at the same time. Hoping to get to 90k before I do!! Good luck either way you go
Old 02-08-2008, 09:23 PM
thegr81's Avatar
Yea if the pump has some serious miles on it I would just replace the whole unit and save yourself time latr on!!!
Old 02-09-2008, 03:24 PM
MHPrior80's Avatar
well the truck has 93,000 miles on it right now...still think i should replace the whole thing?
Old 02-09-2008, 04:43 PM
Kordog's Avatar
I would, why go through all the trouble to pull the tank to put the sensor in, then to fill up to check your gauge, then when you go to start it, it won't start because the pump has failed with a full tank of gas!! Well that would be my luck anyway!! LOL!! So if it lasts to 90K I will be replacing all the parts in there, so I don't need to worry!! Good luck either way you choose to go!!
mladsig
TrailBlazer GMT360/GMT370 (2002-2009) Tech
17
06-08-2009 06:01 PM
2manybroke
12-30-2007 07:59 AM
bobditts
11-04-2007 12:13 AM
dusted800
01-27-2007 10:16 PM
NCStone
07-15-2006 02:52 AM
Quick Reply: Fuel Sending unit
