Gear ratio question(s) fellas!
Old 05-19-2012, 07:01 AM
chevymobbin's Avatar
chevymobbin is on a distinguished road
You can find your RPO codes in your glove box. That will tell you which gear ratio you have now. There is a list on the first page of this thread that will tell you the codes for the various gear ratio's available on s-series trucks. The most common on Blazers is 3.42 (GU6) and 3.73 (GT4). I'm almost positive that all ZR2's came with 3.73 gears.
As for driving with miss-matched front & rear axles, you would be fine as long as you don't have a Bravada with AWD, and as long as you disable the 4x4 by pulling the fuse. This will prevent the front axle from engaging. If you were to engage the 4x4 with miss-matched axles while moving you WILL break stuff. I drove mine for 3 months after swaping my rear axle before I could get the front changed to match.
for me that fuse is never going to be put back in I honestly just never use it. Just in case I dont figure it out where is that lil guy at? (fuse) in the dash or under the hood or as the euro say "bonnet". And I have the GT4 3.73's. I what I was trying to ask is how many inches is the rear end I found a site that had me order by rear end size. or if you post a link to the 4.10 gears that would fit if you have them book marked from when you bought yours?
  #32
Old 05-20-2012, 05:11 PM
SoullessNihilist's Avatar
SoullessNihilist is on a distinguished road
i would drop the front drive shaft if your not (ever) gonna use the 4WD and you change the rear ratio. just in case some idiot ever borrows your car and trys to use the 4WD. you never know!
  #33
Old 05-21-2012, 12:18 AM
yeah thats a good point. is the rear end 7.5"
  #34
Old 05-22-2012, 10:52 AM
El_Beautor's Avatar
Unless you have a ZR2, you should have the 7.5" rear end. The ZR2's had the 8.5" or 8.6".
moosehunt
07-04-2013 09:42 PM
odfareal
09-25-2009 12:07 AM
TomSawyer
05-10-2009 12:40 PM
Outsydr
02-26-2009 10:45 PM
THEBLAZE
02-13-2009 04:15 PM
Quick Reply: Gear ratio question(s) fellas!
