Has anyone converted a 4x4 truck to a 4x2 truck ?
Just out of curiousity, has anyone removed all the stuff out of there 4x4 truck to make it into a 4x2 instead? and is it possible to do that? like will it cause other problems? I have absolutly no use for 4 wheel drive where i live and it just taking up space under the truck making it harder to work under it. not to mention the extra weight im pulling around... anyone do this before?
i guess, it makes changing motor mounts or oil pan gasket a lot easier. i ripped all that IFS crap out of my 93 and put a k5 straight axle under there it is alot roomier. only thing you want to do is break your front axles at the outer boot and put that part back into your bearings as they are said to separate when driving.
Regardless of the driveline, the Brazilian Blazer and S10 used the same frame and suspension setup of the American 4WD versions due to its higher clearance which appeals more to local preferences and regional conditions. You'll just need a longer driveshaft (or an aftermarket overdrive unit).
1funBlazer
09-01-2011 01:28 PM
K5blazer1986
05-30-2009 02:45 PM
76BadSign442
02-01-2007 11:12 PM
