Head Gasket or Intake Gasket - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 12-29-2007, 12:35 AM
01gmcjimmy is an unknown quantity at this point
Default Head Gasket or Intake Gasket
2001 GMC Jimmy 4.3 4wd
I have coolant in my oil, which is more common to go out on these engines the head gasket or the intake gasket. I am hoping the intake gasket to be honest sense I would have less work to do to change it and the parts are cheaper.
Old 12-29-2007, 01:55 AM
blazerboy30 is an unknown quantity at this point
Default RE: Head Gasket or Intake Gasket
Head...
Old 12-29-2007, 04:11 AM
Chevy Lover is a jewel in the roughChevy Lover is a jewel in the roughChevy Lover is a jewel in the rough
I would think that it would be more common for the intake gasket to fail than the head gasket. Normally you will have an external leak from the intake gasket but it is possible to have an internal leak into an oil gallery.
I would remove the spark plugs and do a compression test to be sure.
I'll bet you remove the intake and find broken intake manifold gaskets.
Old 12-29-2007, 08:51 AM
junkmonkey is an unknown quantity at this point
Coolant in oil = Intake manifold gasket failure. Approx. $50.00 (or less) for parts and 6 to 8 hours of labor time should take care of it. IMG failure is fairly common. Good Luck.
FYI: Search around for the "How-To" to fix the IMG's. Read it through a couple times and you'll be fine. It's more grunt work than anything. Taking the top end apart is time consuming but not too hard.
Old 12-29-2007, 10:38 AM
The intake manifold gasket is WAY more common of a problem on this engine. If you did not overheat the engine, then I'm betting on an intake manifold failure. You could dismiss the head gasket with a quick look at the plugs. If you find one that has coolant on it, then do a compression check on that cylinder as well as the others on that side for comparison.
Old 12-30-2007, 12:17 PM
4x4willywill is an unknown quantity at this point
Quote:
ORIGINAL: junkmonkey
6-8hours??? good god man , what speed do you fix things? the speed of smell? lol jk
i would say more like a 2-3 hour job if you did non stop,and have all thepart/s and tools needed...also coolant in oil can =all of these.... cracked head or head gasket, or cracked block, or cracked intake. not just intake mani gasket lol just wanted to bust some chops today lol
Old 12-30-2007, 02:32 PM
I believe junk was quoting book time as this is what most shops charge for particular jobs. Is it right, no. Can it be done faster, heck yes!
Old 12-30-2007, 02:37 PM
oh yeah please dont see me as a "jackass" or "smart ***" that is not my intention
thanks alot
WIll H.
Old 01-03-2008, 12:43 AM
bigv is an unknown quantity at this point
I have a '99 4.3/V-6/4WD with whatI believe is a blown head gasket. There is coolant pouring out towards the back of the engine, spillingunderneath by the tranny. If I fill the radiator up, without the engine running, this happens when it reaches a certain volume. From my visual inspection, looks like I can see coolant coming out of the left bank head gasket, towards the rear of the head. I was quoted $1300.00 to pull both heads, install gaskets, and have any needed machining done on the heads to resolve problem. Wondering if this is reasonable and how difficult this job would be for a do it yourselfer with wrenching ability. Looks like there's alot to remove to get to the heads - time consuming.
Old 01-03-2008, 12:51 AM
its only nuts and bolts man!Hell for 1300$ ill drive to you and do the headgaskets for you! lol...
btw where you reside? city state .
Closed Thread
Thread Thread Starter Forum Replies Last Post
Need new lower intake gasket, is head gasket shot too? Melrock83 Engine & Transmission 3 07-03-2012 07:51 AM
head gasket or lower intake gasket? mylittletonkatruck 2nd Gen S-series (1995-2005) Tech 8 03-07-2012 03:04 PM
Help....blown head gasket or blown intake gasket..? limited edition 1 Engine & Transmission 6 10-21-2011 03:31 PM
INtake Gasket / Head Gasket / Cracked Head J.R. Clay 1st Gen S-series (1983-1994) Tech 2 03-17-2011 09:22 PM
head gasket or manifold gasket LJ809 Engine & Transmission 6 04-25-2010 07:02 AM
Tags
43, 43l, 95, 98, blazer, failure, gasket, gaskets, gmc, head, intake, jimmy, labor, replacing, time, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
