heater control question - Blazer Forum - Chevy Blazer Forums
Reply
Thread Tools Search this Thread
Old 02-18-2013, 11:19 PM
Rumblur is on a distinguished road
Default heater control question
I have a 2000 Blazer with the auto climate controls. My heat is not working, but both heater hoses are warm at the firewall. I am old school, I prefer to control the simple controls... could I change the computer control for a standard 3 **** mechanical controller?
Also - what is the the thing to do when you have both heater hoses warm, and no heat? (again, 2000 2wd 4dr computer climate controls)
Old 02-18-2013, 11:57 PM
Twip's Avatar
the motor for the blend door might have gone out. its pretty simple to check the motor. all you have to do is turn the car on, engine off. wait for all the beeping to stop and then turn the temperature from cold all the way to hot, or vise versa. if you listen carefully you should be able to hear the motor working under the dash. if not then you have your answer.
i dont know how hard it would be to switch it over from the automatic to the manual.
Old 02-20-2013, 07:31 AM
Thanks Twip. This motor you're talking about, is it electric or vacuum?
Reply
Thread Thread Starter Forum Replies Last Post
P0443 / Evaporative Emission Control System Purge Control Valve Circuit Malfunction waviaerith 2nd Gen S-series (1995-2005) Tech 1 05-22-2010 11:02 PM
heater control question jamies96 General Chat 1 12-18-2009 10:05 PM
New. Question about Auto climate control HVAC control panel. kota04sxt 2nd Gen S-series (1995-2005) Tech 10 12-10-2009 10:34 PM
Heater control question. The Beep 2nd Gen S-series (1995-2005) Tech 5 01-27-2009 11:11 PM
(Pic) Heater hoses and control vac lines location MudHawg Full Size K5 Tech 2 12-20-2005 01:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
