Heater Core in 2000 Blazer,,, - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 11-22-2011, 07:43 PM
Matty man is on a distinguished road
Thumbs up Heater Core in 2000 Blazer,,,
How hard is it to swap out a heater core? Its a 2000 Blazer 2wd 2 door,, I had an issue with low heat when cold,, well I tested my radiator cap and it would not even get to 2 psi,, well I flushed (well drained the block & radiator) put in new anti-freeze, 195 theromstat and a new cap,, well before all this the truck never seemed to get up to normal temp on the gauge,, afterwards it goes to 205ish now on the gauge,, and heat was fantastic!! Well until the junk floating around clogged the heater core. So now I will flush the heater and that should help,, and you now it will clog again,, so always check the basic`s. So do I have to pull the dash to do this? Thanks as always,, Matty man
Old 11-22-2011, 07:46 PM
xgiovannix12's Avatar
xgiovannix12 will become famous soon enough
the dash has to be removed to replace the heater core
no way around it
when i did my dads 97 i pulled the dash out of the truck
best thing i ever did
Old 11-22-2011, 08:45 PM
Is pulling the dash a pain?? What about the pass air bag?? I will do a search,, Thanks Matty man
Old 11-22-2011, 08:51 PM
this should have all the information you need
98+ Dash Takeout Tutorial - S-10 Forum
Old 11-22-2011, 09:12 PM
Thanks!! I found the dash removal,, that will help a boat load,, Matty man
Old 11-22-2011, 09:17 PM
best of luck
remember time and patience is the key
it took me 4 hours then an hour the next day to finish the final touches like the hazard switch i broke and cleaned up the cab
Old 11-22-2011, 09:52 PM
pettyfog is a jewel in the roughpettyfog is a jewel in the roughpettyfog is a jewel in the rough
Just wondering.. did you try reverse flushing the core? That's the only way to do it.
But if you're going to replace the core do a proper flush on the entire system
Closed Thread
Thread Thread Starter Forum Replies Last Post
2000 blazer heater core removal bamablazer57 Paint, Body, & Interior 20 04-05-2014 11:50 PM
2000 Chevy Blazer (problems after heater core replacement) piperarrow Lighting & Electrical 1 10-06-2012 04:53 PM
Problem after Heater Core Replacement 2000 chevy blazer zantam06 2nd Gen S-series (1995-2005) Tech 5 08-04-2012 03:00 AM
2000 Blazer Heater Core trstno16 Engine & Internal 19 06-21-2011 09:12 PM
2000 S10 Blazer - Heater Core Headache Marbles Racin 2nd Gen S-series (1995-2005) Tech 7 04-30-2011 08:15 AM
Tags
10, 1995, 2000, 2wd, blazer, cheap, chevey, chevy, core, cores, flush, flushing, heater, information, removal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
