Heater problems... - Blazer Forum - Chevy Blazer Forums
Search
Search
Reply
LinkBack Thread Tools Search this Thread
Old 09-14-2004, 03:08 PM
Maulsmasher is an unknown quantity at this point
Default Heater problems...
I have a 1999 Blazer. The blower works...the A/C works, but the heater does not blow out hot air. I change the thermostate and now I don't know what else to do...anyone know what I should be checking?
Thanks
Old 09-15-2004, 05:14 AM
01xtreme is an unknown quantity at this point
Default RE: Heater problems...
could be the heater coil....?
Old 12-19-2004, 05:32 AM
dawne fischer is an unknown quantity at this point
did you find anything out about the heater problem. we have a 1996 4.3 chevy blazer, and it has the same problem. please reply
Old 12-20-2004, 08:57 PM
Retired Admin
zero psi is an unknown quantity at this point
may be an air pocket in the radiator or block?
Old 12-21-2004, 01:30 AM
jimmy91444 is an unknown quantity at this point
Probably the same probleme I had:
When your engine is warmed up doe's both heater hose get equaly hot? I had the same prob when i bought mine , and the hose from the engine to the heater core was somewhat hot but the one going to the radiator was almost cold.After replacing many parts like you did , I found out that the hole on the engine were the hose connect was almost block with residu. Leaving just a small amount of hot water going to the heater core. After cleaning out the hole i had all kind of heat ..... I ve got the 4.3 lt and the hose has a quick disconect to the engine it sit to te back of engine on pass side . Might be a bit different on yours, hope this help.
_____________________________
91 jimmy 4x4 4 doors
Old 02-26-2005, 10:18 PM
astro is an unknown quantity at this point
I sure hope you got it fixed by now but if not, spend the money and get a full cooling system flush and refill done by a good mechanic. You probibly have restrictions in the system somewhere and need to clean them out.
Old 06-25-2005, 09:50 PM
aspenpup is an unknown quantity at this point
Answering a bit late but for those who find this later...
I had exact same problem. I ended up removing both hoses going in/out of heater core (inside engine compartment). Using compressed air, I blew out the core. There was a big 'glob' of stuff in there that prevented water flow. Now, the heater works great!
Old 07-05-2005, 03:35 AM
BLAZIN is an unknown quantity at this point
My a/c and heat don't blow at all, sometimes when i drive it might turn on, but then shuts off after a few mins. Any suggestions or ideas?
Old 07-07-2005, 05:20 AM
dieselfumes is an unknown quantity at this point
might be electrical, or just the a/c clutch goin out.
Old 08-14-2005, 08:14 PM
Swblazer is an unknown quantity at this point
I had the same problem on my 99 Blazer LT....with electronic A/C
It was a bad solder on the bord in the motor that controlls the blending(airmixing) door for hot/cold air.
I took the motorassembly apart and solder all the connectionpoints and after that it worked again.
But it is very important to have the right position on the turn resistor inside the motor assembly.
Regards,
/Sverker from Sweden
Reply
Thread Thread Starter Forum Replies Last Post
Problems, Problems, Problems... upblazer95 2nd Gen S-series (1995-2005) Tech 3 04-04-2009 09:27 PM
Heater problems LoLoS10Blazer87 2nd Gen S-series (1995-2005) Tech 13 02-24-2006 07:57 PM
Heater problems MarcoMan 1st Gen S-series (1983-1994) Tech 1 12-20-2005 12:35 PM
More Heater Problems Silverfox 2nd Gen S-series (1995-2005) Tech 2 03-15-2005 03:51 PM
1996 chevy blazer heater problems dawne fischer 2nd Gen S-series (1995-2005) Tech 1 12-21-2004 01:16 AM
Tags
1995, 1999, 2000, 98, 99, ac, air, blazer, blog, chevy, cold, coming, controls, door, heater, problems, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
