Good Locker
Good Locker
found one used, price seems reasonable and they are willing to negociate
GM 8.6 10 BOLT Eaton Gov-Lok Posi Trac - Ottawa Transmission, Drive Train For Sale - Kijiji Ottawa Canada.
let me know thanks !
Anyone can give any input ? Its reserved until saturday, just wanna make sure its good before buying it
Thanks
Thanks
Have you made absolutely sure that you have an 8.5 rear axle under the back end of your truck? The 7.625" 10-bolt rear axle is far more common.
Regardless, in my opinion I wouldn't recommend a used (or unknown condition) G80 ever. Sure it's cheap, but you have no guarantees if it is going to work any better than what you have in your truck now...
How would I know if I have that rear end and also, I don't have any right now cause when I spin only 1 wheel will spin
You could research it a bit and determine, through comparison, what rear axle you have. A google search for "GM Rear Axle Identification" should get you started on that front.
You don't have a locker now from the sounds of it, but do you need one? What are you looking to do with the truck?
The G80 is a decent factory diff, but not one I would recommend going through the trouble of setting up & installing especially if you have no idea if it will work as intended.
If you do have an open diff in there now and you want the added benefit of a locker, you can get a drop-in locker like the Lock-Right products that will replace the spider gears inside your current differential with a ratcheting locker unit. They can be finicky.
It comes down to what you want out of your truck and how much money you have to put into it to get there.
off roading and on road :P
i want to it the trails this summer and as much as i can too
is this what you meant ? is there a info page on diff ?
http://www.ebay.ca/itm/Powertrax-Loc...item4843d5f0c5
also i see alot of different diffs on eBay saying 8.5" to 8.6" 30 spline and bla bla.. what do i look for ?
RPO Code says i have GU6 - 3.42 Axel Ratio Rear / G80 Rear Limited Slip...
so should i upgrade for a locker or keep the stocker ?
Last edited by swartlkk; 04-17-2012 at 07:08 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
If you have a G80 diff in there now, you CAN NOT use a drop in locker like you linked to. That can only go into an open carrier.
And there is absolutely no use in looking for a differential until YOU figure out what axle you have under your truck.
you mean the spline ?
i know i have the GM 10 Bolt 8.5" Diff, saw the thread on S-10 Forums to tell the difference between the 7.5" and 8.5" my tubes go bigger going in the main chambre of the ring pinion
also found this in my package :P
ZM6CHASSIS PACKAGE OFF ROAD SUSPENSION
That does not verify the axle that is under your truck. Read through my posts again and do what I suggest. Verify with your own eyes.
your talking about the axels inside the differential ?
and i did go see under my truck to make sure i had the 8.5"
Matty Kling
05-27-2009 02:54 PM
99s10blazer
06-01-2007 09:13 AM
lukewb
14
12-02-2006 02:23 AM
