Help! Won't start after Intake Manifold Gasket repair - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 05-23-2009, 09:58 PM
jspafford is on a distinguished road
Default Help! Won't start after Intake Manifold Gasket repair
Hey all...
Bought the truck cheap because it had the IMG leak. Ran fine 2 nights ago...other than the leak.
I pulled it all apart. The gasket was gone on the rear passenger side. No antifreeze in the oil that I can tell.
So I put it all back together. Fired it up... Well turned the key anyway. Turns over real slow and the tach jumps around. Tried again and got clicking.
Here is my issue. The battery worked fine two nights ago.
I had a question on the wiring. When I hooked everything back up I had a red wire right from the battery cable that I assumed went to the back of the alternator. There was also a second set of two wires I didn't know where they went. They come from a wire loom on the LH side of the back of the motor. One is 12g one is 16ga and the terminate into a ring terminal. They both say 'fusible link' so I hooked it right to the back of the alternator where the positive battery lead is.
I think this might be my issue.
HELP!
1996 GMC Jimmy SLE Auto/4WD/4.3L
Thanks!
Old 05-24-2009, 05:28 PM
Did you make sure to reinstall the distributor correctly? You may want to run through the EDI Engine Timing thread to make sure.
Old 05-27-2009, 12:04 AM
My work checked out... It was a low battery....
Old 05-27-2009, 10:03 AM
That would do it. Glad you got it fixed and thanks for the follow up!
Closed Thread
Thread Thread Starter Forum Replies Last Post
No start after intake manifold gasket replacement awesomeamerican1 Engine & Transmission 2 12-06-2014 01:01 AM
Repair intake manifold leak before or after flushing cooling system? BigDaveH 2nd Gen S-series (1995-2005) Tech 3 04-01-2014 11:12 PM
Shifting Issues after Intake Manifold Gasket Repair DrEaMsTeVe 2nd Gen S-series (1995-2005) Tech 16 02-22-2014 12:51 AM
00 blazer intake manifold gasket repair bofus86 2nd Gen S-series (1995-2005) Tech 4 02-12-2010 06:45 PM
intake manifold gasket repair fred96 2nd Gen S-series (1995-2005) Tech 2 04-23-2007 06:30 PM
Tags
2000, 98, blazer, chevrolet, clicking, cost, distributor, gasket, intake, manifold, put, remove, repair, replacement, start, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
