How to change fuel filter??? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 09-22-2008, 10:58 PM
azembdriver is an unknown quantity at this point
Default How to change fuel filter???
Hey guys,
Any words of advice for a newbie to change my fuel filter??? I was told there is a speacial tool required for the job???
Will it cause a big problem if all the fuel drains out of the line in the process???
Any help will be greatly appreciated!!!
Old 09-22-2008, 11:09 PM
Default RE: How to change fuel filter???
You do not need any special tools. The quick disconnect fitting can be disassembled with a small screwdriver for pushing in the plastic clips. The other side will require some penetrating oil a few times a day for a week prior to the job to make it as easy as possible. You may also want to use line wrenches for the threaded fittings.
Old 09-23-2008, 08:01 AM
Peru Motors is an unknown quantity at this point
hey Kyle-did I miss something-what year it this(OP's) Blazer-does it even have the clips? JP[:@]
Old 09-23-2008, 08:38 AM
Well, provided he posted in the proper section, yes, it should have the quick disconnect fitting on the front and the threaded connection on the back. I believe that all 2nd gens are this configuration.
*EDIT* - I did just look up what he had and it seems that the 95 & 96 trucks are consistent with the 1st gens as far as the fuel filter goes with threaded connections on both ends. So disregard the comment about the quick disconnect.
Old 09-23-2008, 08:52 AM
Kyle-depending on the definition of second gen.(I see it's 95-up) the clip configuration is not used until 98(model year-99% sure of the year). So depending on the year of this Blazer in question-he may only need to break both ends loose(5/8's and 25/32nds/ish), undo the bracket and change. By the way-I still think you've got a serious wealth of info between your ears and as a fellow New Yorker-keep it up! You know your #%@^!JP PS by no means do I have any agenda in correcting your info-just didn't want any confusion for the original poster. And by the way-you were right about my valve job on a 93 Blazer a couple(4-6or so) months ago! See if you remember that one!
Old 09-23-2008, 08:55 AM
I edited my post while you were posting. You were correct. He has a 95 and the 95-96 2nd gens use the same filter as most of the 1st gens which has threaded connections on either end. I had assumed that with the change in body style, they would have changed over to the newer setup. 97 was the first year of the quick disconnect outlet.
Old 09-23-2008, 08:56 AM
portcqb is an unknown quantity at this point
97's have the quick connect also.
Old 09-23-2008, 09:00 AM
Gotcha there again as well! LOL
Anyway, suffice to say that to get the filter off as easy as possible, use lots of penetrating oil a few times a day for a few days before attempting to remove the filter. Having the proper line wrenches will also help greatly reduce your chances of rounding over a line fitting.
Closed Thread
Thread Thread Starter Forum Replies Last Post
fuel filter change GONE WRONG.... ryito1122334455 2nd Gen S-series (1995-2005) Tech 24 07-29-2011 01:04 PM
Change fuel filter in 2002 Blazer 4x4? busta_bird 2nd Gen S-series (1995-2005) Tech 8 01-11-2011 05:38 PM
Need some guidance on fuel filter change Vicer_Exciser 2nd Gen S-series (1995-2005) Tech 12 11-28-2010 10:54 PM
95 Blazer Fuel Filter Change. kickme005 2nd Gen S-series (1995-2005) Tech 1 08-24-2010 09:22 AM
how do i change a 94 4dr blazers fuel filter? classklown90 1st Gen S-series (1983-1994) Tech 1 09-03-2009 11:53 PM
Tags
1985, 85, 93, blazer, change, connect, disconnect, filter, fuel, gm, line, olds, quick, replace, undo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
