How do the quick connect transmission cooler lines attach to the 4L60E tranny?
Old 03-17-2007, 08:20 PM
broke33's Avatar
broke33 is an unknown quantity at this point
Default How do the quick connect transmission cooler lines attach to the 4L60E tranny?
I just purchased a 1996 Chevy Blazer 4x4 and it had a front pumpeal leak. I pulled the trans out, replaced the seal and Im putting it back in. I have the bellhousing bolted up, but I cant figure out how to get the transmission lines to connect. They have these little spring clips and the lines are a compression fit. I push the lines in as hard as I can with one hand while taking the other hand to push in these spring clips. I cant get them in. Is there something Im missing? Do I need a special tool?
thanks
Old 03-17-2007, 08:25 PM
Chevy Lover's Avatar
Default RE: How do the quick connect transmission cooler lines attach to the 4L60E tranny?
Install the clips into the connector, then push the line into the connector. Give the line a pull to make sure it's snapped in secure.
Old 03-17-2007, 08:28 PM
Damn! Beat me to it!!
Old 03-18-2007, 08:03 PM
broke33's Avatar
Thanks for the info, but I cant get these lines to snap in. How hard do I need to push? Is it easier to unscrew the adpaters on the side of the trans, snap the lines in, then screw the adapters back in?
porkfriedrice
06-03-2023 02:35 PM
InsanePyro
10-17-2014 09:11 AM
bearsfaninwisc
01-07-2012 08:32 AM
Jonboy
06-07-2010 06:24 AM
Jetfixer
07-11-2006 05:02 AM
Quick Reply: How do the quick connect transmission cooler lines attach to the 4L60E tranny?
