How do you remove steering wheel cover? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 07-21-2008, 06:23 PM
Smoked is an unknown quantity at this point
Default How do you remove steering wheel cover?
I'm talking about the piece of plastic on top of the steering column that the hazard switch pokes through on a 99 blazer. I have the bottom piece off, 2 screws and unclip it but the instructions i have for the top say there's a screw to remove and i can't find one. I have my mirror all around this thing and i can't find a screw, but it's snug around the ignition.
Anyone?
Old 07-21-2008, 10:36 PM
Megalodon_Al is an unknown quantity at this point
Default RE: How do you remove steering wheel cover?
Very frustrating.... have typed reply three times with no success. I hope someone can help with this because my Haynes manual says wheel must come off on airbag equipped trucks. Anyone have different experience? I need to change my multifunction switch.
Old 07-22-2008, 09:53 PM
Sorry for posting in the wrong section, but does anyone know how to get this cover off? Do we have to remove the steering wheel?
Old 07-25-2008, 06:31 PM
Well, i figured it out. I did some searching and found there is a 'reverse torx' screw and sure enough there is(didnt' know what that was until i saw it). It's on the ignition side of the panel. I got it off with a 5/32 socket and voila there's the top bolt for the turn signal switch. (incidentally no part number on the hazard switch.
So i took the top torx screw out of the switch easily enough but the one on the door side is tough because of the steering wheel. I got a really big vice grip and pinched the torx bit in there and very slowly removed the screw. The wiring was a bit of a pita but not as bad as what i'd just finished so the old one came out in about an hour i'd say(i could do it in 15 mins now ).
So i put my replacement switch in from a wreckers and wouldn't you know it..the wipers work, the squirt works but the high beam wouldn't stay on and there was no hazard or turn signals
I double=checked my wiring and it's all good...so the switch i bought was crap.
Man i'm pissed...that was a lot of work and some scraped up knuckels and now i have to buy a brand new one afterall. I should have just bit the bullet right off. Buy good parts and do the labour myself is probably the best in the run. Oh well..tomorrow it's off to the dealer to get a new switch. Hopefully i can return the one i bought that doesn't work.
I'll try to take pics when i reassemble tomorrow... it's really not as bad a job as it seemed and all the searching indicated. If I can do it, anyone can
Old 07-25-2008, 07:31 PM
Tried editting above...stupid board problems
Anyways, false alarm i just forgot the turn signal and sir fuses ... once back in everything works. Truck is back in one piece and i have no more clicking(except when i command..mu ha ha)
Closed Thread
Thread Thread Starter Forum Replies Last Post
how to remove inspection cover off of transmission bell housing kmartin Engine & Transmission 2 06-03-2014 05:23 PM
Is anyone rockin' a steering wheel cover? tibby Paint, Body, & Interior 5 09-27-2011 09:58 PM
Remove steering wheel or not? gmbwrenchn 2nd Gen S-series (1995-2005) Tech 5 12-17-2010 07:18 PM
Cargo cover/Jack storage cover frankjc General Tech Help 2 08-07-2006 11:12 AM
Tags
03, 1994, 1995, 94, 98, blazer, camaro, chevy, column, cover, covers, remove, removing, steering, wheel, zr2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
