How many O2 Sensors?
Old 02-27-2009, 09:47 AM
cjbehrens's Avatar
cjbehrens is an unknown quantity at this point
Default How many O2 Sensors?
Can someone tell me how many O2 sensors I have to replace and where they are???
Old 02-27-2009, 10:36 AM
Default RE: How many O2 Sensors?
Been covered before and I have posted this image depicting the oxygen sensor locations in a few different posts:
What is happening that you are considering changing the O2 sensor(s)? If you are doing a general tune up, only the B1S1 & B2S1 sensors should be considered for changing as the B1S3 (post-cat) is an emissions monitoring device only and should only be changed if a code specifically stating a problem with that sensor and all diagnostic procedures have been completed resulting in the conclusion that the sensor is in fact at fault.
Old 02-28-2009, 01:30 AM
cjbehrens's Avatar
I purchased my Blazer back 1n 2006 @ 96,000, and here I am about to hit 130,000. My LS says that I'm getting 14.4 mpg and I am about to do as complete of a tune up is possible before I start adding all the mods I want ie. AEM CAI, Gibson Exhaust, JET ECM programmer, CFM-Tech Ported Throttle Body and JBA headers.
Old 02-28-2009, 01:37 AM
cjbehrens's Avatar
So the O2 Sensor labled as #1 in the diagram does not need to be changed unless it codes???
Old 02-28-2009, 10:29 AM
ORIGINAL: cjbehrens
Isn't that what I said...? It has nothing to do with engine fuel management.
Old 02-28-2009, 11:14 PM
cjbehrens's Avatar
I wa just confirming thanks.
melstal
03-31-2015 05:08 PM
scphill34
03-31-2013 09:41 PM
jeff771
04-12-2012 11:37 AM
Supercity
07-10-2011 01:23 PM
s10machine
02-10-2009 10:25 PM
Quick Reply: How many O2 Sensors?
